Machine Vision
VBAI2011 Save for Previous Version option
Since VBAI 2011 is one of NI products, I am curious that it has an option of Save As For Previous version like Labview, or is there any way around it?.
I currenlty have running Labview 8.6 in my systems which doesn't work well with VBAI 2011. What I have done is using Labview 2012 evaluation version to re-save my VI 8.6 till to 2010 version. I am thinking an option of down-grade my VBAI if possible.
Thanks.
Hoa Huynh
University of Minnesota
(4,063 Views)
Not sure if you're aware, but you can use the Vision Builder API in LabVIEW to control an any version of VBAI 2010 or greater with any version of LV 8.5 or higher. There is a shipping example located in your Vision Builder AI\API Examples folder. The API has several advantages over migrating your inspection to LabVIEW, so you might want to check it out. Here is a web video of how to use the API to control VBAI, run inspections, and get the results and images:
https://www.ni.com/en/shop/electronic-test-instrumentation/application-software-for-electronic-test-...
Hopefully Vision Builder will eventually support saving for previous, but until then, using the API allows you to use a variety of LabVIEW versions with a variety of VBAI versions.
Hope this helps,
Brad
(4,052 Views)
Brad,
Thank you for your quick response.
I definitely will try it out.
Hoa Huynh
Hoa Huynh
huynh213@umn.edu
(4,031 Views)
