Machine Vision
Imaq get pixel line
Hello.I don't good speack english, but I have a problem. The received arrays of lines Line 1 and Line 2 have the different sizes. And, "radius Line 1"="radius Line 2"="size array Line 1",but no= "size array line2"("size array Line 1">"size array line2"). How can I receive identical array sizes of Line 1 and Line 2 using thus functions IMAQ? And how I can good delete a signal noise and receive the histogram with all peaks of ring on the extract line?(histogram on the picture 3).
(5,470 Views)
Hi Marsee,
I'm not sure how you would force theuser to make the lines both the same length.  However, why do you need this functionality?  Are you trying to do some processing later in your program and running into problems with the array sizes?
Marti C
NI Medical
(5,433 Views)
The Chancenator wrote:
Hi Marsee,
Hi, Marti,
Very very strange question. The user need such functionality, because frustrated with different line length which is depends from the line direction.
So,  it depends from the method for pixel counting. When line strictly horizontal or vertical, then each pixel behind of line inserted into array. But when line is diagonal, then some pixels crossed partially. So, not all pixels added to result and resulting line length is shorter than original (but take a note - if you will measure length of the line with measurement tape, then bots exactly the same):
Butr we can calculate triue length and then interpolate, quick and dirty something like that:
 Now both profiles are the same:
Hope it helps,
with best regards,
Andrey.
(5,415 Views)
