First off I've mainly been a java programmer so C++ is taking some getting used to. I am trying to acquire images using a PCI-1424. I am using the imaqGrab function to acquire them on a signal from the camera. But unless the signal comes shortly after pressing the capture button, a fatal error occurs. It says the session timed out. Is there some way in C++ to do a "Try/Catch" statement like in java? Or is there some other way to just skip or hide the error? Also someone mentioned that since I was using the Lab Windows API that it was an error code instead of an exception and that a "Try/Catch" wouldn't work.
