I talked to Carl and he suggested that I post an answer to your question. First I will attempt to answer your question, and second I will make a suggestion.
In essance the Frequency Analysis to which you are referring is a quick way to do a Bode of a block diagram. In the old days of MATRIXx say before Version 4 you were required to work at either the command prompt or in the SystemBuild editor therefore such a convenience was important. Since the advent of Xmath however you can execute commands at the Xmath interpreter a the same time that the SystemBuild window is open. The menu item is significantly more restrictive than the command line.
As Carl had pointed out you are really only allowed to change the u0 in the GUI kicked off from the menu item and what you
are asking is to change the x0.
You could actually make this occur from the menu item with a fairly detailed understanding of GUI programming and the underlying file structure of the menu items however it would not be worth your time since you could achieve the same end by simply performing a lin on the superblock of interest at the Xmath prompt like:
sys=lin(mysuperblock, {x0=myx0});
Where myx0 is defined in Xmath.
Now you only need perform the Bode since "sys" is now a linear system which is a pertibation state-space model and therefore will have all states around zero.
The simplest way to do this is again at the command line.
Bode(sys);
If you find this helpful please let us know. If not I am certain that we can assist further.
Now for the recommendation. I think that it would be most prudent to upgrade your 6.1 version to 6.2.2 because of the high robustness of this later version.
Garrett
Garrett Thurston
gthurston@foliage.com
Phone: 781.993.5540
