Linux Users
Setting up NI-cDAQ 9184 in Linux Environment
I have an ethernet compact daq (NI-cDAQ 9184) that I'd like to use in a Linux environment. I already have a computer running Scientific Linux 6.6 (32bit) that has another National Instruments product installed (a PCI 5114 digitizer), so I thought I'd use the same system. The libraries installed are NI-Scope 3.1 and NI-DAQmX 8.0.2.
When I try nilsdev on the Linux computer only the PCI card shows up as a recognized device. I have a Windows computer on the same network that has been able to identify the cDAQ, so I know it's on the network. I suspect that the the cDAQ needs a later version of NI-DAQmx for Linux but haven't been able to find a document with the right infromation- does anyone know?
As a follow-up question, I have seen posts in this form about a version 15 of NI-DAQmx for Linux being available - is it possible to have two versions of NI-DAQmx running at the same time, one for the PCI card and one for the cDAQ?
Thanks!
(4,780 Views)
To reply to my own question, it looks like I had missed all the other posts in the forum asking the same question - the short answer is that  ethernet based cDAQs do not have Linux support. But for future reference, for anyone who stumbles across this and has the same problem, these are the posts to look at:
http://www.ni.com/white-paper/14095/en/  - shows which cDAQs have Linux module support
posts reiterating that there is no Linux support:
- https://forums.ni.com/t5/NI-Linux-Real-Time-Discussions/cDAQ-Support-on-NI-Linux-RT/m-p/3451090#9929...
- https://forums.ni.com/t5/Linux-Users/Support-for-ethernet-cDAQ-modules-under-Linux/m-p/3402642#41754...
- https://forums.ni.com/t5/Linux-Users/Support-for-ethernet-cDAQ-modules-under-Linux/m-p/3402644#43643...
posts suggesting using a virtual machine as a workaround:
- https://forums.ni.com/t5/Linux-Users/cDAQ-9188-with-Linux/m-p/3438854#23496%2323496%2323496
- https://forums.ni.com/t5/Linux-Users/CompactDAQ-in-Virtualbox/m-p/3387305#9432%239432%239432
- https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x2CMCAY&l=en-US
I have also heard that another (hard) workaround is to do register-level programming of the cDAQ, to bypass the need for nidaqmx:
- http://sine.ni.com/nips/cds/view/p/lang/en/nid/11737
(4,445 Views)
