NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Knight of NI
Ray.R
Re: EEG processing
Hi viginesh,
Sorry for the very late reply..  Did you resolve this?
(starting to) See Life in a brand new way...
b* ^ )
Member
Steve.J
Re: EEG processing
Hi Viginesh,
Spectral monitoring of EEG signals is pretty straightforward.  Normally, the time domain signal is broken into short epochs of a few seconds and an FFT is performed on that data array.  The data from the FFT is binned into frequency ranges according to standard EEG definitions:  Delta, (0-4Hz), Theta (4-8Hz), alpha (8-12Hz) , etc. The Peak power value in that frequency range and/or the cumulative power (total power in that bin) is reported.  Then the next segment of EEG data is processed and this continues either in real-time or on a prerecorded file of EEG.  This process is duplicated for each channel of data corresponding to different locations on the brain.
Another common EEG processing task is looking for abnormal spike activity that is associated with epilepsy and is sometimes the precursor to seizures.  Various methods are employed, including template matching, wavelets processing, and even neural net processing.
Can you tell us more about the actual processing that you need to do on your EEG data?
Steve
Visit the NI Biomedical User Group at:
www.ni.com/biomedusers
Member
ncwstuff
Re: EEG processing
It's all in the time based site specific voltage pattern, just look there.
Member
Steve.J
Re: EEG processing
Sorry - I need more to go on than that...
Member
viginesh
Re: EEG processing
Thank You all.... I have completed my project... Thank u very much
Knight of NI
Ray.R
Re: EEG processing
Glad you completed it.
I got lost in the translation somewhere...  then got confused..
nevertheless, the improtant part is that you got it working.
R
b* ^ )
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
