LabWindows/CVI
duplicate watch
Using CVI 2013
After adding an expression to the watch window, after several runs of the code and then re-opening the watch window, the watch expressions are duplicated.
This problem did not occur in previous version (cvi 2010)
Please advise
(5,585 Views)
John,
Is it possible that you're closing the Watch window and then terminating the execution? This is known to cause the behavior you describe, and is being tracked by R&D in CAR 472358. The workaround is to leave the Watch window open when terminating executions.
Let me know if you're seeing something different--we'd want to document the behavior if there are other causes of the issue.
(5,540 Views)
exactly as described in your response
Is there an option to keep the watch window open at all times?
(5,496 Views)
I notice that CVI now has a service pack 2, with fancy graphics on the watch window.
BUT STILL THE PROBLEM OF REPEAT POPULATING
why has this feature become corrupt from previous versions of CVI and how did it get past product test?
Please fix before releasing service pack 3
(5,293 Views)
still happening in cvi 2015 - opportunity to sort this missed
(3,997 Views)
