07-19-2006 03:11 AM
07-19-2006 03:28 AM
Hello Flavio
in the AnsiC library there are several functions for file I/O: fopen, fclose, fread, fwrite, fprintf, ... Check the Input/Output class of the AnsiC Library.
Labwindows also has it's own functions for File I/O. Check File I/O in the Formatting and I/O Library.
If you have any specific questions about using these functions, just post again...
07-19-2006 03:48 AM
07-19-2006 04:31 AM
07-19-2006 09:12 AM
Under the Help menu of CVI select Find Examples. Look under Fundamentals then File Input and Output for examples on how to handle file io. Look under Hardware Input and Output then DAQmx for examples on how to acquire and access data in an array. That should get you started.
There are some great examples that you can run to see how various things behave or can be done. If you have any more questions please feel free to post them here.
Good Luck
