LabWindows/CVI
Splitting a string over several lines in a c file
I know this is more a question about the c language and not really a CVI issue, but I hope someone can help me out here.
I wonder if it is possible to split a string over several lines in a c file. I'll give an example:
Suppose I have the very large string that I am using in a Formatting function:
Fmt (string, "Hello all. This is a very large string, containing %i characters which I would like to split over %i lines.", num_chars, num_lines);
Now, I would like to split this code into two lines. Is there any character I can use to split this string, e.g.
Fmt (string, "Hello all. This is a very large string, containing %i characters \
where the \-character would be the character to split the string (like you can use in a macro).
Thanks for all help,
Wim
(3,922 Views)
You can split it like this:
Fmt (string, "Hello all. This is a very large string,"
    " containing %i characters which I would like"
    " to split over %i lines.", num_chars, num_lines);
The compiler will concatenate contiguous literal strings, that are separated only by white space.
JR
(3,921 Views)
Thanks a lot JR Smiley Very Happy
(3,916 Views)
