I have put some of your suggestions together and came up with a
solution. I wrote a little example program that does the trick. The
program is called RegisterTest. After installation, the user is asked
if he wants al *.regtest files to be opened automatically with the
program RegisterTest.exe (All this program does is show the filename).
How it works:
In the Advanced Distribution Kit options I enter RegisterTest.exe as
the executable to run after setup, and "Register File Type" as command
line. This causes the program to run after setup wit the arguments
"RegisterTest.exe", "Register", "File" and "Type". If these arguments
are detected in the main function, some values are added to the
registry, so the system recognises the extension *.regtest as a
RegisterTest file.
The code:
int main (int argc, char *argv[]){
char projectdir [MAX_PATHNAME_LEN];
char reg_str [MAX_PATHNAME_LEN];
if (argc > 1){
if (!StrICmp (argv[0],
"RegistryTest.exe") && !StrICmp (argv[1], "Register")
&& !StrICmp (argv[2], "File") && !StrICmp (argv[3],
"Type")){
if
(ConfirmPopup ("","Do you want to register the filetype *.regtest to
RegistryTest.exe?")){
RegWriteString (REGKEY_HKCR, ".regtest", NULL,
"RegistryTest");
GetProjectDir (projectdir);
sprintf (reg_str, "%s\\RegistryTest.exe %%1",
projectdir);
"RegistryTest\\shell\\open\\command", NULL, reg_str);
else MessagePopup ("Filename", *argv);
return 0;
