LabWindows/CVI
Mixed checkbox
Is there a possibility to create a mixed checkbox like in labview (https://zone.ni.com/reference/en-XX/help/371361R-01/lvhowto/configure_mixed_checkbox/)
(1,765 Views)
If the mixed checkbox is the three-state unit with checked, unchecked and partially checked states like this one:
then I suppose you could fake it with a picture ring and a bit of coding: the click must switch checked / unchecked states, while the partial check is given programmatically when some other condition is met (in the above case only some of the child elements are checked).
(1,727 Views)
