LabWindows/CVI
LoadPanelEx error -94 when dll called from TestStand
Calling my LabWindows/CVI DLL from Teststand
I am getting Error -94 File not found from
panelHandle = LoadPanelEx(0, "Some.uir", PANEL, 0)
Target setting "Embed project .UIRs" is checked on the DLL project
If I step through the code within LabWindows/CVI I do not get the error
If I operate the DLL through a CVI executable application, I also do not get the error
The panel does not require user interraction.
Any Ideas?
(2,446 Views)
Accepted by topic author krugman3
Swapped
for
panelHandle = LoadPanelEx(0, "Some.uir", PANEL, __CVIUserHInst)
Now appears to be OK.
(2,415 Views)
