LabWindows/CVI
How do I check that the TCP server, the client is connecting to has gone down?
I'm trying to write a routine on the client side which tries to reconnect when the TCP server goes down.
I am using the Lab Windows TCP functions.
Currently I'm checking for a less than 0 value returned on a ClientTCPRead call, but instead I see that when the TCP server goes down, my program just waits and does nothing. I have set my read timeout to 2 seconds.
Any suggestions would be greatly appreciated!
Thanks.
(5,588 Views)
If your TCP Server closes connection, the TCP Callback function you registered while connecting to the server gets automatically an event
//Connection to the server:
iErr = ConnectToTCPServer (&g_hconversation_client, iTelnetPortNumber, sIPAdresse, ClientTCPCB,
NULL, 5000) ;
// your CB function:
int CVICALLBACK ClientTCPCB (unsigned handle, int event, int error,
void *callbackData)
switch (event)
case TCP_DISCONNECT:
//your reacting code
sprintf receiveBuf, "TCP_DISCONNECTeceived. Server has closed connection.");
(5,589 Views)
That is exactly how I'm handling for a disconnect from the server, but for some reason, the client never gets the TCP_DISCONNECT event.
Is there a known bug in LabWindows CVI 6.0 ?
And also would there be any workaround to it? If I were using simple socket library functions I could just check if recv() returned a 0, but by using LabWindows functions i dont know if that would work..
Thanks!!
(5,588 Views)
I am doing exactly same thing what you are trying to do. Here are my functions.
int CVICALLBACK Auto_Connect_To_Server(void *functionData)//This is a thread.
int status;
do
status = NC_Connect_To_Server(Server_name, Client_name);
ProcessSystemEvents();
}while(status != 0);//wait until connected
return 0;
int NC_Connect_To_Server(char *server_name, char *client_name)
int status;
DisableBreakOnLibraryErrors();
memcpy (Server_name, server_name, strlen(server_name));
memcpy (Client_name, client_name, strlen(client_name));
status = ConnectToTCPServer (&handle, PORT_NUMBER, Server_name, NC_ClientCB, 0, TIMEOUT);
if(status == 0)
return NC_PASS;
// Connected = 1;
else
return NC_FAIL; //Error occured
Thanks.
CVI 2010
LabVIEW 2011 SP1
Vision Builder AI 2011 SP1
(5,588 Views)
Sir,
I am using LabVIEW instead of LabVIEW CVI.
I am having one Server and one Client VI. I need to include an option such that if I start the client VI first, it should check whether the server is ON. If no, I should stop executing telling that Server is in OFF condition. How can i do it in LabVIEW using TCP-IP functions.
Kindly clear my doubt.
Ramkumar. D
Engineer.
Ramkumar.D
QuEST, INDIA.
(5,489 Views)
Hi Ramkumar,
If you want the Client to check if the Server is running, just set a timeout value for the "TCP Open Connection.vi" that is the maximum you want to try to establish a connection to the Server. If the server is not running, you will receive an error 63 (The network connection was refused by the server).
Have fun!
- Philip Courtois, Thinkbot Solutions
Thinkbot Solutions
(5,470 Views)
