11-01-2006 09:39 AM
11-02-2006 05:33 AM
11-02-2006 08:18 AM
11-02-2006 08:37 AM
You can put more than one graph control on a panel. But it seems to me that you are intending to plot two signals on one graph, and again the answer is yes: having a graph you can plot as many items as you want to it. Every single plot, be it a single point or a complex waveform, recibes a handle by which it can be accessed to modify its attributes, hide, show or delete it.
In your case, you can simply use PlotWaveform or PlotXY multiple times on your graph.
Just to point a few terminology: with "graph" normally a graph control is intended, that is the grid/axes/legend group that permits to draw a signal on it; a "plot" is the individual signal drawn on the graph: it can be a point, a line, a shape, a text... Plots are created via Plotxxxx command in the user interface library and require a graph control to place them on.
