LabWindows/CVI
Error: Out-of-bounds pointer argument (before start of array).
I'm having a weird problem:
In a function, I declare a string "char label_str[20]".
Later in this function, I want to use this string to hold the label of a picture control. So I use the function
GetCtrlAttribute (my_panel, my_picture_control, ATTR_LABEL_TEXT, label_str);
When the debugger executes this function, I get a FATAL RUN_TIME ERROR: Out-of-bounds pointer argument (before start of array).
Labwindows is indicating 'label_str' in the GetCtrlAttribute function (marked in blue).
I really have no idea what's causing this error. Smiley Sad
so all hints and tips are really welcome...
Message Edited by Wim S on 01-06-2006 12:21 PM
(5,034 Views)
Hi!
   I think defining your string as
   char *label_str;
    label_str=malloc(20*sizeof(char));
   etc....
   should solve.
  I've also found this, in CVI help:
Constant:  ATTR_LABEL_TEXT
Data Type:  string (char *)
Description:  The text label for the control.
Control Types:  All except Text Message, Decoration, Splitter
In the description of ATTRIBUTE VALUE for GetCtrlAttribute() function.
Let me know how you managed this problem!!!!
graziano
(5,027 Views)
Hi Graziano,
Thanks a lot. Your solution seems to work.
(5,023 Views)
Hi!
   Thanks for feeding me back! Smiley Very Happy
graziano
(5,019 Views)
