LabWindows/CVI
Check Box size with "Use Windows Visual Style for Controls" enabled
When a panel has the option "Use Windows Visual Style for Controls" enabled, a Check Box control can't be resized.
I mean that I can set its size through "Edit Check Box" or "Control Coordinates and Dimensions" (SHIFT+F10) window, but the size of the check box doesn't change (see attached)
Is this an expected behavior?
The size of Square Radio Button can be easily changed.
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(7,010 Views)
Vix,
Unfortunately, Windows does not allow you to resize checkboxes. This is a common problem for many Windows developers and the workaround is typically to create your own checkbox. The good news is that since CVI has it's own version of the checkbox for non Window's styled controls. Use the Disable Panel Theme attribute of the checkbox control to disconnect it from the Windows visual style and use the CVI version.
(6,997 Views)
Returning to this issue 8 years later, I can't find Disable Panel Theme among the property nodes or the Properties page of the checkbox.  How would I do it? Does this ability still exist?
(4,282 Views)
"Property node" sounds like you are programming in LabVIEW, while in this board we are discussing on LabWindows/CVI controls. Since I see that you usually post in the LV board, it seems today you have landed to the wrong one Smiley Wink
(4,269 Views)
