I've been browsing and reading a lot and I just can not seem to find my way around this ActiveX world hidden away in the COM technology world of Microsoft. On the Other hand looking at the ActiveX samples is CVI it seems pretty simple and straightforward unless you want to do something new outside the scope of the few and sparse examples on the subject. The Wizards in CVI works absolutely great, but again, I'm faced with a jungle of options when I'm trying to create a new controller. So I ventured into this forest but soon found myself lost and way in over my head, but I have this nagging feeling that it should be really simple if you can only find the small pieces of information in this haystack of Microsoft documentation to piece it together.
So my objective and bear with me if my understanding and interpretation of ActiveX was wrong. I want to use ActiveX to gain access to my incoming mail messages on Outlook (2000,XP,2003)scan the content and apply a Bayesian filter to it and move the mail to a different folder based on my analyses. In Theory this operation should be transparent between various versions of office, hence the initial objectives of COM and it's subsequent derivatives, but this does not seem to be the case, so it seems like you have to create a separate controller fp for every version of Office, determine the version and then use the appropriate calls.
So back to formulating my initial question(s):
1. My understanding is that I need to create a ActiveX Controller, is that correct?
2. From the very long list of options (servers) which one is most suited for achieving my objectives
3. Once I've created a new fp, how do I determine in what order to call these functions to do what I need to do.
Is there some appropriate references out there that I can reference or is the MS jungle of endless loops and reams of mambo jumbo my only solution.
Any advice or pointers in the right direction will be much appreciated.
Best regards
Jattie van der Linde
Engineering Manager, Software & Automation
TEL Magnetic Solutions Ltd
