NI Home
Cart Cart | Help
You are here:
Announcements
The NI Idea Exchange is a product feedback forum where NI R&D and users work together to submit ideas, collaborate on their development, and vote for the ones they like best. View all of the NI Idea Exchanges to post an idea or add your opinion on an existing one today!
vix
Creation of subfolders in the project window
Status: In Beta
by Active Participant vix on ‎10-13-2010 01:49 AM
In the project window you can organize the project files into some "virtual" folders (Source Files, Include Files, ...)
If you right-click on the project name, you can add a folder with the item "Add Folder...".
If you right-click on one of these folders, you can add one or more files files.
But it's impossible to create a subfolder of one of these folders.
Every large project has a lot of files (sources, ini-files, images, icons, ...), so I think it's quite common having them saved into different "real" folders and subfolders. If you don't explicitly add these files to the project, you can add them to the distribution kit browsing your hard disk "real" folders, but in this situation the absolute path of the files is used. And if you move all your project from a PC to another one you won't be able to recreate the distribution kit without errors if you don't save the whole project to the same folder you use in the first PC.
And this is a really big problem.
For files explicitly added to the project, instead, the relative path is used, and this is OK, so the best situation is to add all the files in the project window.
So it's necessary create a full structure of virtual folders and subfolders.
Status: In Beta
Comments
by Active Participant LuisG on ‎12-13-2010 09:27 PM
Status changed to: Under Consideration
by Active Participant JonathanN on ‎03-27-2013 11:48 AM
Status changed to: In Beta
About LabWindows/CVI Idea Exchange
Do you have a feature idea for how to improve LabWindows/CVI? Submit and vote on ideas now!
  1. Browse by label or search in the LabWindows/CVI Idea Exchange to see if your idea has previously been submitted. If your idea exists, be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click New Idea to submit a product idea. You should submit a separate post for each idea. Watch as the community gives your idea kudos and adds their input.
  3. Give kudos to other ideas that you would like to see implemented!
  4. NI R&D will review ideas that have been submitted and update the status.
Note: the LabWindows/CVI Idea Exchange is not the appropriate forum to submit technical support questions.
The LabWindows/CVI R&D team is committed to reviewing every idea submitted via the LabWindows/CVI Idea Exchange. However, we cannot guarantee the implementation of any LabWindows/CVI Idea Exchange submission.
Idea Statuses
Top Kudoed Authors
