the Advanced Analysis Library provides some convenient functions for array operations; unfortunately some of them are available only for the 1D case and not for twodimensional arrays. While it is no big deal to add a loop I suppose that these AAL functions are speed-optimized, something that cannot be achieved when using the native CVI compiler.
Hence I'd like to suggest the addition of functions Clear2D, Set2D, Copy2D
Wolfgang,
I'm not sure I understand the suggestion. What would expect to see as the parameter of one of these functions (say, Clear2D), and how would you use it?
In C, you can't specify a 2D array as a parameter to a function, unless it has a fixed row size. For example, double array[][10] is a valid parameter declaration, but double array[][] isn't. This is because the row size has to be known at compile-time so that the compiler can generate the object code to index it correctly.
The general rule is that an n-dimensional array must have fixed length for the first n-1 dimensions.
Luis
You must be a registered user to add a comment here. If you've already registered, please log in. If you haven't registered yet, please register and log in.
Note: the LabWindows/CVI Idea Exchange is not the appropriate forum to submit technical support questions.
The LabWindows/CVI R&D team is committed to reviewing every idea submitted via the LabWindows/CVI Idea Exchange. However, we cannot guarantee the implementation of any LabWindows/CVI Idea Exchange submission.
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
