Currently, there is no way to access the historical data on a stripchart. The only way to manage this data is to maintain a separate buffer and update it whenever you add data to the strip chart, which is inefficient and tedious. Accessing data is possible for graph controls using the data attribute:
GetPlotAttribute (panel, PANEL_GRAPH, plotHandle, ATTR_PLOT_XDATA, &data);
Something similar should be implemented for the strip chart, either as an attribute in the getTraceAttribute function, or as a standalone function (getTraceData, etc.)
