winspec and activex
Hi All,
     I have a windows 7 computer with labview 2010 (v10.0) and winspec 2.6.2, Im trying to control winspec in labview via ActiveX.  The problem I have is that whenever I try to call on a winspec library object (such as IExpSetup) I get an error saying that "Library not registered"
Winspec was never designed to run in windows 7, could it be that when you open winspec it doesnt properly register its classes and object in ActiveX in windows 7?
Thanks for all your help!!
Message 1 of 17
(7,395 Views)
Hi syampols,
  It is true that you must register any com dll or activex first.For that go to command prompt and type regsvr32 command followed by the winspec 2.6.2 com dll(This you will be accessing thorugh activex).Else use this utility i attached.
Thanks and regards,
srikrishnaNF
Srikrishna
Message 2 of 17
(7,390 Views)
Hi and thank you for the speedy reply, I have already tried the regserv32 thing and it doesnt work, mainly because it is an .exe file and all the objects are contained therein
Message 3 of 17
(7,380 Views)
Hi syampols,
  Whether Winspec uses any dlls or it is just an exe?Can you send the link ,where i can download the winspec and try.
Thanks and regards,
srikrishnaNF
Srikrishna
Message 4 of 17
(7,370 Views)
for the activex portion of the commands, just exe
Message 5 of 17
(7,355 Views)
hey, did you ever resolve this problem? I'm stuck at the same point.
Message 6 of 17
(7,059 Views)
Was a windows 7 problem in my case. works without problems in XP.
Message 7 of 17
(7,048 Views)
I had the same problem and could resolve it by running winspec.exe once as administrator. Then the activeX library got registered and it worked. However, I now have problems from time to time reading the spectrum (these I never had before on XP with the same code). So there might be still some issues with winspec on windows 7 computers. I would recommend running winspec on a dedicated XP machine.
Best wishes,
Martin
Message 8 of 17
(7,046 Views)
I did resolve it, I do not have any idea how, ill have a look
Message 9 of 17
(7,044 Views)
This is quite old topic but I will push it up.
I have winspec 2.5, We are changing to a new computer with windows 7, and I also have problems with registering ActiveX libraries under Win7.  Any hints?
Message 10 of 17
(6,747 Views)
