when the extended CAN is used why the arbitration ID is ORed with 0x20000000
when the extended CAN is used why the arbitration ID is ORed with 0x20000000?
Mahadev
(2,975 Views)
What makes you think it is OR'ed?
The extended CAN ArbID is 29 bits so any bits higher than that have no meaning.
(2,973 Views)
That is the way NI can handle extended message id's.
They probably have some logic that checks the 30th bit.
You just have to mask out that bit when you are reading the arbitrationid.
(2,970 Views)
