urgent help on array
Hi
I want to Sort an array elements with help of Row 0 in the order of another array.
Message 1 of 13
(4,428 Views)
Hi nitya,
  Please try to use the mathscript node with command as [c,d]=sort(a,b) where a is a matrix/2-d array and b=0/1 where 1-sorts matrix by row and 2-sorts matrix by column.Please check.
thanks and regards,
srikrishnaNF
Srikrishna
Message 2 of 13
(4,420 Views)
hi
I have'nt used math script can u post me the code pls.
Message 3 of 13
(4,418 Views)
Is there any other way apart from using math script ??
Message 4 of 13
(4,416 Views)
Hi Nitya,
  Can you please reattach your Vi ,i could not able to download it..
THanks and regards,
srikrishnaNF
Srikrishna
Message 5 of 13
(4,412 Views)
Hi
please find the attachment
Message 6 of 13
(4,403 Views)
Hi nitya,
  If you install openg toolkits,you will get one function by name sort array which can sort 2-d arrays also either ascending ro descending,row or column wise..I attached the same vi(version 2009)..Find it in the attachments.
Thanks and regard,s
srikrishnaNF
Srikrishna
Message 7 of 13
(4,384 Views)
Hi SriKrishna
I'll check it out.
Message 8 of 13
(4,378 Views)
Sorry, the text:
"The values alone in the Refix array should be replaced in the orginal array with referance to row 0 in original array.
The Row 0 is default only the corresponding values should be picked up from refix and should be placed it in the original."
Is incomprehensible to me. 😞
Could you add a third array to the front panel that shows what kind of result you actually want?
For example if the original array is:
B1  B2 B11  B9
 1   z   z   z
 0   z   z   z
 1   z   z   z
And the refix array is:
B9 B11  B2  B1
 2   2   2   2
 2   2   2   2
 2   2   0   2
What would the desired result look like?
The Row 0 is default only the corresponding values should be picked up from refix and should be placed it in the original.The values alone in the Refix array should be replaced in the orginal array with referance to row 0 in original array.The Row 0 is default only the corresponding values should be picked up from refix and should be placed it in the original."
Message 9 of 13
(4,369 Views)
The result should be
B1  B2 B11  B9
 2   2   2   2
 2   2   2   2
 2   0   2   2
Message 10 of 13
(4,364 Views)
