03-04-2009 10:16 AM
Hi there,
I am building a vi which recieves a set of data, and then needs to find the peaks in the data (there should be no more than 3). The problem is that the peaks are variable in amplitude, depending on the source and I need a method of controling the threshold without having to examine the raw data. The ideal solution would be a graph being displayed with a horizontal line whose height / distance from the threshold and is actively controllable.
Any ideas?
03-04-2009 10:30 AM
