text in non-resizable windows is cut off
Running Labview 6.1 on Windows XP.
Text (i.e. instructions from Labview program) gets cutoff in Labview windows.
Seems like text is too big or window is too small.
Changed font sizes in Windows under Properties->Settings; however, this made no difference.
Any ideas how to solve this problem?
(3,209 Views)
Did you change the font size under appearance (right-click on the desktop and select properties -> appearance)?
What theme are you using...try switching to the Classic theme e.g.
(3,209 Views)
Thanks for the reply...
Yes, that was the first thing I tried. Changes the font on other things on the screen but not in the Labview window.
Changing theme did not work either.
(3,209 Views)
Found it...it's the font size in the LabVIEW preferences. Normally all the fonts (application, dialog etc) is 13 points...if you have any of them set larger it will make a mess. Seems a bit strange they allow such a thing to happen.
(3,209 Views)
