scxi and drivers?
I have a SCXI 1000, with a 1100 unit, a scxi 1520 unit and a scxi 1600 unit. Now when I connect it, I only get a "USB not recognize unit".
I have installed NI-DAQmx 9.1 and LabVIEW 9.01 32 bit, do I need more? I have never tried to use SCXI before.
I runs at Windows7 64bit.
Thanks in advance.
Message 1 of 21
(7,745 Views)
Try restartting the system and if still does not work uninstall the drivers and reinstall
Regards
Guru (CLA)
Message 2 of 21
(7,721 Views)
Hm I have already tried that 😞
Message 3 of 21
(7,715 Views)
did you manually tried addding this new hardware by "add hardware" wizaed in the "control panel"?
Guru
Regards
Guru (CLA)
Message 4 of 21
(7,706 Views)
Hm it wont seems to add it, but it found it under units, complaining about missing drivers?
Message 5 of 21
(7,696 Views)
Have I all the drivers in DAQmx or do I need more?
Message 6 of 21
(7,694 Views)
its not because that I run Windows 7 64bit??
Message 7 of 21
(7,692 Views)
Hmm I found this for NI-DAQmx 9.0.2;
The following devices are not supported in NI-DAQmx on Windows 7 (64-bit version) or Windows Vista x64:
  • NI DAQCard-6024E 200 kS/s, 12-bit, 16 analog input channel, two analog output channel, 8 digital I/O line, two counter/timer device
  • NI DAQCard-6036E 200 kS/s, 16-bit, 16 analog input channel, two analog output channel, 8 digital I/O line, two counter/timer device
  • NI DAQCard-6062E 500 kS/s, 12-bit, 16 analog input channel device
  • NI DAQCard-6715 for PCMCIA 1 MS/s 12-bit analog output device
  • NI DAQCard-DIO-24 for PCMCIA 24-channel 5V/TTL/CMOS digital I/O device
  • NI SCXI-1600 USB module
Does anyone know if the NI SCXI-1600 works with Windows 7 64 bit, in the new version 9.1?
Message 8 of 21
(7,682 Views)
Accepted by topic author BjarneDK
For those USB devices, there are not currently plans to add support for 64-bit operating systems.  This is due to incompatibilities between the USB design of these older devices and the USB implementation in 64-bit version of Windows.
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
Message 9 of 21
(7,663 Views)
Thanks, that explains my problems. Well I guess that I just have to go for Windows 7 32bit, instead.
Thanks for your help.
Best regards
Bjarne Pedersen
Message 10 of 21
(7,658 Views)
