scan from string does not recognize AM/PM flag
I am using Labview 8.6. I want to parse a time string, with an AM/PM flag inside, but the "scan form string" time format code
"%<%d/%m/%Y %I:%M:%S %p>T" does not recognize the AM/PM flag. The remaining string containes the AM/PM flag.
best regards,
Friedrich Vollink.
Message 1 of 8
(4,918 Views)
Example with default values.
Message 2 of 8
(4,911 Views)
I think Format string is wrong..it should be "%<%H:%M:%S%2u%m/%d/%y>T"
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
Message 3 of 8
(4,906 Views)
It works now. I toggled AM/PM time format on my laptop (control panel/local settings).
Thanks for the reply.
Friedrich Vollink
Message 4 of 8
(4,900 Views)
Accepted by topic author FriedrichV
The solution is:
define the AM and PM symbols in the control panel\regional settings\time  Pffffffffffffffffffffffffffff
Friedrich Völlink
Message 5 of 8
(4,873 Views)
I'm using LV2010 and the AM/PM flags are defined in the control panel/local settings, but I still have the same problem!
Format String:  %<%m/%d/%y %H:%M:%S%p >T
Input String:
05/06/11 02:15:56 PM
Output Time Stamp:
2:15:56.000 AM
5/6/2011
Remaining String:
PM
Message 6 of 8
(4,760 Views)
Did you read the help for time format strings? You cannot use 'H' for 24 hour time and the am/pm flag.
Message 7 of 8
(4,748 Views)
Thanks, Missed that!
Message 8 of 8
(4,730 Views)
