ruska 7000 driver conversion
Can someone convert this file from Version 5 (I believe) to Version 8.6?
I thank you an advance.
Otman
Message Edited by Otman on 09-14-2009 09:44 PM
Message 1 of 10
(5,583 Views)
Why do you want to convert it? it work in 8.6.
Message 2 of 10
(5,448 Views)
Accepted by topic author Otman
How do you figure that?
VI's from that old of a LV version need to be opened in a bit newer version such as LV 7.1 through 8.5, in order to be opened up in either LV 8.6 or LV2009.
Try this llb in version 8.2.
Message 3 of 10
(5,438 Views)
Correction:
VI's from that old of a LV version need to be opened in a bit newer version such as LV 7.1 6.0 through 8.5 8.2, in order to be opened up in either [LV8.5],  LV 8.6, or LV2009.
I would recommend using either 7.1 or 8.2.
Here is the link to the version compatibility chart.
Message 4 of 10
(5,424 Views)
Oups! Sorry about that. I had it in my user.lib and I was sure that it was working. Sorry.
Message 5 of 10
(5,413 Views)
Hi Otman,
Here ya go. Mass compiled in LabVIEW 8.2.1. You should be able to open this in LabVIEW 8.6. Be aware that the VIs in the LLB may not function as expected if the functionality of any of the VIs changed from LabVIEW 5 to LabVIEW 8.6. This is simply to be able to open the VIs.
Message 6 of 10
(5,401 Views)
Dr. Horrible wrote:
Hi Otman,
How is this different from what I posted yesterday in reply #4. ????
Message 7 of 10
(5,394 Views)
Hi Ravens Fan,
Oops. Sorry, I didn't see that you had reposted the LLB.
Aaron Pena
http://www.ni.com/support
Message 8 of 10
(5,392 Views)
Thank you all who responded. Your help is so kindly appreciated.
Message 9 of 10
(5,374 Views)
I looking for the driver for the RUSKA 7615. This driver will work in my equipment? Do I need to convert to Labiview 17?
I intend to measure the pressure and save the datas.
Regards
Message 10 of 10
(3,955 Views)
