06-26-2009 08:36 AM
Go to Waveform Measurement and use the FFT Spectrum (Mag-Phase).vi
Then use a waveform data type instead of the dbl-array, set the dt value to the inverse of your frequency (as used in the filter). Also use the waveform for the filter.
You also have a spectral Measurement Express vi. But here the same applies: Use a waveform data type to have the timing information.
Felix
06-29-2009 06:06 AM
I tried to do what you said, but i don't if It's good. I put my program in attachment, Can you say me if it's good or not ?
Thank you very much,
Sylvain
06-29-2009 06:43 AM
It is very hard to get much out of a word document. Please post your code instead. We understand you are a beginner so we will not hold some beginners mistake against you;)
Also before you send your VI go to Edit in the toolbar and select "Make current values default" Then save it. This way we will have all your data and settings
06-29-2009 08:27 AM
Yes, It's right I am a beginner in Labview and I would like you help me because it's very important for my internship.
I put in attachment my VI program, and several data files. The names of the data files are the roughness (Ra) I should find theoritically.
Thank you very much for your help
Sylvain
06-29-2009 09:35 AM
07-01-2009 05:06 AM
What do you think about my filter, it s good or not ?
Sylvain
07-01-2009 05:07 AM
Sylvain
07-03-2009 05:03 AM
07-06-2009 10:11 PM
Hi Sylvain,
In your filter setting, you can set "window" input to "Hanning", "filter type" to "Lowpass". Then adjust the "Low Cut-off frequency" input, such as 25Hz, or 50Hz.
Beside the filter, you can also use the Cubic Spline Fit.vi. Please see attached VI. Try to adjust the "balance parameter" of Cubic Spline Fit.vi, such as 1E-6, to see the change in "Profile of Roughness" graph. I set the default value to 1E-7.
Michael
05-01-2013 08:56 PM
Hola, lo que necesito es un vi que mediate una adquisición de datos analogos de voltaje de un sensor de 4 cuadrantes, ya tengo las coordenadas X, Y y de ahi calcular la profundidad de la muestra mediante el desplazamiento del laser en el sensor y el algulo de incidencia. ¿Alguien pude ayudar?
