09-10-2009 04:35 PM
A VI inside the Report Generation Toolkit (version 1.1.2), Excel Find Application Directory.vi, will not function correctly when running an EXE. The "Current VI's path" block will return the path of the currently running EXE rather than the path of the Excel Find Application Directory VI. (The same would be true for Word Find Application Directory.vi.)
-Joel
Solved! Go to Solution.
09-11-2009 02:48 AM
Do you get error7 ?
Christian
09-11-2009 09:18 AM
09-14-2009 09:52 AM
Have you had a look at this knowledgebase article? The error is caused due to the exclusion of any dynamic VI.
Ipshita C.
09-15-2009 10:43 AM
