read the raw image file
Hi Gabriele,
I tried your code and came across the same error.  I found that if I took the picture data and used the Picture to Pixmap VI to convert this back into a pixmap, I was able to save the data as a JPEG file.  The Picture to Pixmap VI is located in the Functions palette under Programming -> Graphics & Sound -> Picture Functions.  I have included a screenshot of the code below.
I hope this helps.
Rishee B.
Message Edited by risheeb on 01-18-2008 02:26 PM
Message 11 of 13
(2,545 Views)
Great! That solves it!
Thank you very much!
Gabriele
Message 12 of 13
(2,525 Views)
I have a similar problem that needs help. I'm using an industrialized camera. However, the labview program comes with it can only output 8-bit image. I am trying create a program that will only output the raw data image not the processed image. Any suggestions?
P.S. I'm a new user to LabView and I'm using the 2012 version.
Thanks.
Message 13 of 13
(1,749 Views)
