12-19-2011 10:11 AM
hi,i am working in pwm,i have the next code in labview to control it with compactRIO
http://imageshack.us/photo/my-images/24/pwmlabview.png/
the problem is that i don´t understand the flat sequence structure and the components which are conected to it
somebody could help me with it?
thanks
Solved! Go to Solution.
12-19-2011 11:09 AM
This forum allows you to upload images and VIs directly. Please use that functionality rather than third-party sites.
The reason for the flat sequence structures is that the Wait function does not have error terminals, so there is no way to dictate order of execution without wrapping it in a structure. The code sets the digital output ON, waits for a specific amount of time, sets the digital output OFF, and then waits for a second amount of time.
12-19-2011 11:43 AM
ok,sorry about the image
so,the first flat sequence structure works just at the high time and when that time is finished, the second flat sequence structure works at the low time?
or if the first or the second works,depends about the digital input?
12-19-2011 11:50 AM
Both sequence structures always execute on each iteration of the while loop. The first sequence structure waits during the ON time. The second waits during the OFF time. The wire carrying the error cluster (the gold/black wire in the image) dictates the order of execution because it is an input and output from both the digital IO nodes and the sequence structures. If this isn't clear, turn on execution highlighting (the light bulb icon in the toolbar) so you can watch as it runs.
12-19-2011 12:26 PM
thanks
