Hi...
I have a problem using peak detection under Analysis=>waveform monitoring.
I want to get the real data (ECG data), and detect the peak of the data. Then i want to store the index of the peak into array so that i can measure the time difference between two peaks.
my problem is that when i use peak detection, i cannot get the result as above mentioned. Before this i have tried to test the peak detector and found that if it will detect the peak for 100 ms time interval only. SO if i have waveform with f=100 Hz, then it will detect only 10 peaks..Is it correct that this vi takes 100 ms sample for detection? *correct me if i'm wrong
And since i want to get the real data from ECG hardware, is there any method to measure index of the occurence of all peaks and store it into array? (not only for 100 ms)
-I saw the formula in peak detector help :
To view the locations in terms of time, use the following equation.
Time Locations[i] = t0 + dt*Locations[i]
What does [i] here represent?
Thanks for the help...
Rismi *newbie...:d
