online system identification NI-6008
Dear All,
I have problem when handling my system identification toolkit. When I running my system in real time, i get this error;
"The model orders are inconsistent with the dimensions of the model coefficients."
How can i settle this problem. I don't know what is happening actually. I hope some can give some suggestion, why this situation occur. The problem happen when the ouput of ARMAX or ARX system model out connected to SI Conversion. I make the connection cause of to draw the tranfer function.
Thanks All.
(2,507 Views)
Hi saifizi,
the ARX or ARMAX model needs X values to calculate the model. The number of the samples [X] correlates with the model orders.
You have to handle the error for the first X sampels.
For your ARX example (A order = 1, B order = 2) the model needs 3 sampels to calculate the model.
(2,396 Views)
hello .. i also use ni usb 6008 for online system identification motor dc , but i confused and i'am newbie using labview
can you help me ? 😞
(2,299 Views)
I would suggest going through the getting started guide to LabVIEW materials. There should be sufficient material there to get you started on both software and hardware.
http://www.ni.com/getting-started/labview-basics/
For the System Identification Toolkit, I suggest looking though the help file to learn more about how to use the functions.
http://zone.ni.com/reference/en-XX/help/372458D-01/
(2,277 Views)
