not updating with local variable
Hi everyone,
i have a  problem about no updating with local variable in my programm,can anyone give me some ideas?here post i my code.thanks in Advanced
note;Labview 2009 Sp1
(2,403 Views)
Accepted by topic author jetfire
Hi jetfire.
Your local variable is working fine - however you need a while loop around your case structure. Otherwise will your case structure only get executed once, when you press the run button.
Best Regards
Alex E. Munkhaus
Certified LabVIEW Developer (CLD)
System Engineer
(2,397 Views)
