04-29-2013 04:33 AM
I need a make a program that explores the one-dimensional numeric table and counts the number of values in the table two controls to the range of
04-29-2013 05:14 AM
So if i understand ik correctly you need to loop true a 1D array with numbers and count the values that are in range of a set of values givin by an input.
I think you need to check the "In Range and Coerce" function from the compare pallet in a autoindexed for loop.
04-29-2013 05:23 AM
I use while loop box and case structure box...
04-29-2013 05:26 AM
try to share your code. it will help us solving the problem.
04-29-2013 05:36 AM
There is what i have done allready.
04-29-2013 06:05 AM
Hi temes,
you need to check your comparison functions: right now both try to compare for the upper limit...
Btw you can achieve the same without a loop:
When your arrays are large (more than 32767 elements) you should convert the output of the "?1:0" function to I32...
05-02-2013 03:19 AM
How can I do this by using loop? Like I have start to doing!
05-02-2013 03:22 AM
05-02-2013 03:31 AM
Can You do and put a picture for that? I can't do this right.
05-02-2013 03:35 AM
Hi temes,
you're not able to debug your own VI? Really? Even after getting told what's wrong??? Come on...
