mxLvProvider.mxx required for executable
Does anybody know why my application executable all of a sudden needs the file "mxLvProvider.mxx" to be in the data directory?
The application builder puts it there automatically, but I do not know what it is for. If I remove it my application does not run, instead the usual file prompt dialogue pops up when I run the application.
Also, can anybody shed any light on what this file is for? My PC seems to think it is a "MAX Configuration UI" but that does not make any sense either.
LV2015SP1 on Win10, no NI hardware involved.
Crossposted here.
(5,528 Views)
I am not sure but are you using TSVN?
(5,519 Views)
I am using TortoiseHg, but not from inside LabVIEW, only from Windows.
(5,512 Views)
I did find that post when searching for answers previously, but I do not think my problem is related. My builds are fine (although I have not tried to create an installer, I use Inno Setup for my installers).
(5,497 Views)
Accepted by topic author Neil.Pate
Update: this is caused by including the Get Build Specification Version VI (\vi.lib\AppBuilder\AB_API_Simple\Get Build Specification Version (path).vi)
For various reasons I needed to know the current build number, and found that VI to do it. Unfortunately this causes a bunch of extra dependencies to appear in the project and the necessity of this mxLvProvider.mxx in the built application, so for me is not a pleasant solution.
(5,410 Views)
