11-28-2006 09:46 AM
11-28-2006 10:37 AM
I would advise writing your own dialog VI, which you will then be able to dismiss automatically on timeouts or other conditions. You can use dialog controls to make it look like the system dialog box.
See the Three Button Dialog VI for an example. If you want to see a better example, I believe you should find one if you search the LAVA forums for "dialog".
