installing arduino interface toolkit
hello every one i want to install arduino interface toolkit but when i do this through vipm i face to this error any one cane help me?
(3,056 Views)
Accepted by topic author anoosheh
Labview->Tools->Options->VI Server->Machine Access-> add 127.0.0.1 or/and localhost then retry
Edit: Also make sure Allow access is enabled.
uday
(3,054 Views)
Also, you should probably use the LINX toolkit instead as it's the newer and supported toolkit for Arduino: https://www.labviewmakerhub.com/doku.php?id=libraries:linx:start
(blog)
(3,044 Views)
I can't get LINX to work with 2016. Is it no longer supported?
(2,778 Views)
LINX Remote I/O (Arduino, chipKit, etc) is supported in LabVIEW 2011 or newer and the 32-bit version of LabVIEW is highly recommended.
LINX Local I/O (ie deploying to BeagleBone Black and Raspberry Pi 2/3) is only supported in LabVIEW 2014 SP1 (32-bit).
Bryce B.
NI AE
(2,755 Views)
