how to use adb with labview
im trying to communicate to a tablet via ADB using labview with the sys exec function but i havent been able to retrieve or send data,
if i do it manually using the command prompt it works perfect, but not with LV
if you can help me
thanks
(4,822 Views)
Hi tokyghy,
What happens when you try to do the communication in LabVIEW? Do you get an error? Are you using proper error handling in your code to know if an error is thrown when you try to execute the code? Thanks!
Kira T
(4,801 Views)
Can you post your code so we can look at it and maybe figure out what is happening?
Rob
(4,793 Views)
hi, well i do not have a code yet because im still searching for information to learn the adb commands and that stuff you need to fully communicate, Im new with this,so thats why i was asking for some ideas
thanks for reading my posts.
here is a code that was posted few months ago by a guy that was trying to do exactly the same thing, but i havent tested it yet. i dont know if the commands are correct
(4,786 Views)
