how to store jpeg images in SQL server using NI database Connectivity Toolset. Can anyone please help me in this regard.
Please tell how to store jpeg images in SQL Server using NI Database Connectivity Toolset.
Message 1 of 10
(4,854 Views)
How about storing the images as files on a filesystem and then store the filepath to the images as a string in the databse?
Dan
Message 2 of 10
(4,835 Views)
Storing Images as files is not a secured way. The images can be deleted by anyone. Can I directly store the images in the database?
Message 3 of 10
(4,827 Views)
You can convert the images to a byte array and store the byte arrays in the database.  This is not recommended for storing large images or a large nmuber of images.  Most will recommend storing the path to a file on a filesystem as I previously suggested.
How about creating a more secure filesystem that is only accesible via your LabVIEW application?
Dan
Message 4 of 10
(4,809 Views)
Thanks for suggestion. Can you please tell how to make a secure filesystem that is only accessible trough Labview?
Message 5 of 10
(4,796 Views)
Set the secutiry options so Users group only has Read access, and the LV-programs account has Read+Write.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 6 of 10
(4,788 Views)
The application has to be installed on many computers with different users and they also have to store images in the same folder. How can I make that folder secure? Therefore I have to store the images in SQL server. For that can anyone please help.
Message 7 of 10
(4,772 Views)
http://www.w3schools.com/sql/sql_datatypes.asp
You setup a field as BLOB and store the binary of the picture there. Depending on the database it can be called differently as you can see in the link, in SQL server there's even a Image datatype.
/Y
Qestit Systems
Message 8 of 10
(4,761 Views)
The NI Database connectivity toolset only have six data types in the create table VI i.e. String, Long, Single, Double, Date/Time, Binary. But it does not have BLOB data type. Even in the binary data type it does not store too much data of the image. It gives an exception error. Please help in this regard.
Message 9 of 10
(4,757 Views)
You can write a sql statement and Execute query, that might be what's needed here.
/Y
Qestit Systems
Message 10 of 10
(4,743 Views)
