how to simulate one joint robotic arm
       I want to simulate a one joint robotic arm in labView robotics toolkit.
      Please help me to get start to make one joint robotic arm.
    Looking for your kind hlep
    M Abbas
Message 1 of 20
(8,852 Views)
I don't have that toolkit but have you looked at this shipping example of a robotic arm?
C:\Program Files\National Instruments\LabVIEW 2010\examples\picture\robot.llb\robot.vi
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 2 of 20
(8,831 Views)
Accepted by topic author mujahid
Hello mujahid,
I've constructed a 2 link robot arm with a rotating joint for your reference.
Andy Chang
Message 3 of 20
(8,830 Views)
Thnaks sir a lot for your kind help . Can you tell me how can i control this one joint arm with EMG signal .
Wating for your kind reply.
Message 4 of 20
(8,787 Views)
By controlling the robot arm with EMG signal do you mean using EMG signal to define your joing positions? If that's the case, you can use AO from your DAQ read, interpret it as joint positions, then feed that into the joint position input.
Andy Chang
Message 5 of 20
(8,783 Views)
Please also see our Biomedical User Group located at www.ni.com/biomedusers
We have a free, downloadable Biomedical Starter Kit that includes tools for biosignal processing, including EMG processing VI's.
Steve
Message 6 of 20
(8,780 Views)
The attachment you have attached is of labview 10 and it is not opening in 09 so can u please send me the file which can open in LabView 09 at
kabra@iitp.ac.in
or
vishalkabraiitp@gmail.com
Message 7 of 20
(8,440 Views)
Hi Visha,
I've saved the file as a 09 version for you.
I hope this helps.
Josh L.
Message 8 of 20
(8,412 Views)
This is a perfect example of defining a robot arm. I am new to labview and was looking for something like this for days. But there was a problem in the design. The error shows that Error 310041- Possible reason(s): LabVIEW Robotics: (Hex 0xFFFB44E7) The number of elements in the joint position, joint velocity, or joint acceleration array is not equal to the number of links in the serial arm. Make sure the number of elements in the array matches the number of links in the arm. I want to impliment a robotic arm of 5 DOF, Using servo motors (similar to lynuxmotion robot arm) and then interfacing through serial cable to a microcontroller (probably microchip's PIC). I saw a similar arm design in the examples. But there was no block diagram for it. Can u please correct this error and reupload the file and guide me. Regards Omer
Message 9 of 20
(8,285 Views)
Hi andy, i see this is a great example of how to build robotic joints and simulate them, but i have a problem when simulating, it appears this error
(LabVIEW Robotics:  (Hex 0xFFFB44E7) The number of elements in the joint position, joint velocity, or joint acceleration array is not equal to the number of links in the serial arm. Make sure the number of elements in the array matches the number of links in the arm.)
so would you please help me with this?
thanks in advance
Message 10 of 20
(8,223 Views)
