how to remove channel from DAQmx create Task.vi
Vikas H. Kumthekar
ASE
Tata Consultancy Services
Pune-1
(2,870 Views)
How are you using the DAQmx Create Task.vi? Are you using it to include a global channel or copy a task that was previously created in Measurement and Automation Explorer (MAX)? If this is the case the only way to remove a channel would be to delete the global channel or modify the physical channels for that task in MAX. If you are creating a new task you can use the DAQmx Create Channel.vi to specify the physical channels that you would like to include or exclude.
Andy F.
(2,853 Views)
