how to plot error bars on XY Graph?
I want to create the following plot using XY Graph (and not the 2D Error Bar plot). Can someone help?
I can do this using the 2D Erro Bar plot, but I don't like it because it is very hard to manipulate the 2D Error Bar plot.
I can't even copy and paste the plot easily into MS PPT because 2D Error Bar plot is XControl (whatever that means).
X1 Y1 Err1 X2 Y2 Err2
1 2 0.8 1.5 6 0.7
2 4 0.8 2.5 8 0.7
3 6 0.8 3.5 10 0.7
Message 1 of 17
(9,602 Views)
Hi murchak,
you could simulate the ErrorPlot by creating several plots in the XY-graph.
- Create a plot for each error bar
- Create a plot for all error bars of one "Y"-plot, separate the individual error bars by "NaN" to avoid the connecting line between them.
Message 2 of 17
(9,599 Views)
You could try playing around with this example: error bars in XY plots
Message 3 of 17
(9,587 Views)
Thanks GerdW.
But I don't know what you are suggesting.
Message 4 of 17
(9,576 Views)
Thanks smercurio.
I played with that example before I even posted this, but couldn't get anywhere.
Message 5 of 17
(9,575 Views)
@murchak wrote:
Thanks smercurio.
Then you should indicate what you have already tried, what worked and what didn't work, or what doesn't meet your needs. This way we don't waste our time hunting down possible solutions which you've already eliminated.
Define "couldn't get anywhere".
Message 6 of 17
(9,570 Views)
Hi smercurio,
Please open up my VI to see what the problem is. Error bars from some points are missing, and colors are a little messed, which I think I can fix, but I have to get the first part right.
I have the main VI, and my raw data in two text files (file 1 and file 2).
I also wanted to attach the sub-vi from your link (which I am using in my VI, I had already download this), but I can only have three attachments.
Message 7 of 17
(9,564 Views)
I may not have attached the updated plot vi
Message 8 of 17
(9,559 Views)
You need to expand the legend on the combined plot so that you set the point style on the additional plots (there are 4 plots).
You do not need to do any of that array manipulation inside the loop. All you need is a Build Array outside the loop.
Message 9 of 17
(9,551 Views)
I did exactly that, but the Y error bars are missing from the middle points:
Message 10 of 17
(9,548 Views)
