how to delete columns from a 2D array
Hi guys,
I read a matrix from a text file and I want to delete the first and last columns of the matrix. I've been trying to do it with delete from an array function but it doesn't do it the way I want. Any suggestions?
Message 1 of 16
(18,540 Views)
Hello Elnaz7,
Here's one way to do it.
Andy Chang
Message 2 of 16
(18,534 Views)
Thanks but this deleted the very first row instead of column.
Message 3 of 16
(18,530 Views)
my mistake, that was for deleting rows... here's the column one...
Andy Chang
Message 4 of 16
(18,523 Views)
Yes, it works, thank you.
Now another question: If I want to feed this data to another module row by row for example in a for loop how should I do that?
Message 5 of 16
(18,519 Views)
drop a "for loop" on theram and  Block diagram and look for the help. (CTRL+H). There are some good examples also available so that you can be familiar with using the for loops.
Guru
Regards
Guru (CLA)
Message 6 of 16
(18,503 Views)
Keep in mind that by default, 2-D LabVIEW arrays are row-based. So though you might be thinking that the first indexing input for the 'index array' primitive is for columns, it is actually for rows. You can either select the second input for the 'index array', or, if you are like me and think better in columns, you can transpose the array before you operate on it. I recommend getting used to the order of the inputs for the array tools and forcing yourself into the LabVIEW convention, as it gets complicated if you need to invert an array before you operate on it, and then again after so that the array returns to row-centric order, which is what all the rest of the LV array tools are expecting
Good luck!
Wes Ramm, Cyth UK
CLD, CPLI
Message 7 of 16
(18,485 Views)
Hi Elnaz7,
Have you researched some of our examples and tutorials for manipulating clusters and arrays?
Here is a tutorial I feel you should go through: http://zone.ni.com/devzone/cda/tut/p/id/7571
Regional Account Manager
NI
Message 8 of 16
(18,453 Views)
hi
 how to delete  rows from  2d array.Those rows which are having number of ones(1) greater than a certain number has to be deleted.Can you please help me
Message 9 of 16
(17,212 Views)
Hi dfsfdsfv,
Check whether this meets your requirements.
______________________________________________
Kudos are welcome
Message 10 of 16
(17,202 Views)
