how to convert "True" string to boolean
Hi All,
I've strings as "True" & "False". I want to convert to boolean so that I can change the value of check box control.
Thanks & Regards,
Shrinivas
Message 1 of 17
(26,180 Views)
Hi Shrini,
simply compare for equality with a string constant "TRUE" (maybe do some upper- or lowercase conversion before for easier string handling...)!
Message 2 of 17
(26,180 Views)
Thanks for solution. Can we convert it using TypeCast or by another way?
Shrinivas
Message 3 of 17
(26,178 Views)
You cant use type cast. Type cast will change it to boolean no doubt but not to true and false respectively. Gerdw's solution is simple isnt it?
Message Edited by muks on 08-05-2009 03:09 PM
Message 4 of 17
(26,172 Views)
You could do something as simple as a case structure 🙂 This has a case-insensitive option on the right click menu.
Message Edited by macaba on 08-05-2009 04:40 AM
Message 5 of 17
(26,170 Views)
Message 6 of 17
(26,166 Views)
A rudelberg one.....:smileyvery-happy:
Message 7 of 17
(26,162 Views)
Haha muks- isn't LabVIEW great; it tempts you to overcomplicate things!!
Message 8 of 17
(26,159 Views)
Absolutely............... :smileyvery-happy:
Message 9 of 17
(26,155 Views)
Lol  :smileyvery-happy:
Message 10 of 17
(26,145 Views)
