how to call QTP scripts using labview
Whether any API or dll calls can be used to access the QTP scripts?
(3,387 Views)
There are few mentions of QTP on this forum. Is there an API to call QTP from other programming languages, like C, VB, etc? Like a DLL, or an ActiveX interface, or something? If so, you may be able to access this API from LabVIEW.
(3,369 Views)
I think there we can execute QTP script from command line. Please look for that option. If that option is there, we can use the same command in LabVIEW cmd line interface to execute the QTP script. Curretly I am using TestPartner which is more similar to QTP.I am executing my TestPartner script through LabVIEW using command line interface.
(3,359 Views)
Thanks i will look into it and come back
(3,329 Views)
