how to calculate the ratio between the maximum and minimum peaks of the two waves using two looping to find the value of SPO2?
hello everyone,
i'm rai from indonesia
I have a final project about pulse oximetriy, I have some problems,
how to calculate the ratio between the maximum and minimum peaks of the two waves using two while loops to calculate SpO2 ?
My program image can be seen below predicament ?
(4,016 Views)
Hi rai,
I would appreciate it as kind of respect for forum participants if you would clean up your VI before uploading it (or images of its block diagram)…
That being said:
- Your inner while loops each run exactly twice. Replace them with FOR loops!
- Lots of unneeded operations, mainly induced by ExpressVI usage. Is there a reason to convert to DDT and immediately convert back to 1D array?
- You already calculate some Min/Max values. Ratio is just a division of two values…
(4,000 Views)
