help me by design the required thing..
Please any one give me idea for making the operation. The attached VI shows the check box(regulated) in front panel with some text boxes below. So, now i want to make when the check box is clicked(on or regulated) i want to display last two text boxes with front labels and when it unchecked(off or unregulated) i want display first six text boxes with front labels. So, when the user try to enter alphabets in that textboxes it should not take those and give error message like only numbers are allowed. Attachment is there and please any one can make that for me. i am really new these lab view and looking for big help .(Starting from burst duty ---> current limit)
             Please help me.
please help me i waste 3 days for this and i did not find any way. Looking for big help.
Message 1 of 17
(4,040 Views)
You are already being helped in your original thread. Please stick to that thread so people know what has already been discussed.
Message 2 of 17
(4,035 Views)
Yes,
         But i dont know that really what is doing and also some chanes has done on that file. please i am in do or die sistuation. I dont want to waste my time from now. i tried for one week and still nothing result.
             Please understand me and do for me..
Message 3 of 17
(4,029 Views)
I tried the thing what i said you. But i did not get any result if i clicked the checkbox(regulated) on the running time.
                Please, this the last chance i hope from your side..help me.
Message 4 of 17
(3,994 Views)
The checkbox is disabled. Right click on it and select properties and change it to enabled. Edit: For some reason it was NOT disabled in the first attachment, the one without the event structure.
LabVIEW 2012
Message 5 of 17
(3,983 Views)
You have a two nested loops, the big one (with visa read and write) wont loop until the inner one (the event structure) exits. This'll only happen once you click Stop. So You'll read and write VISA every time you click stop ... Is that what you want to do?
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 6 of 17
(3,953 Views)
An easier way to handle the hide/unhide is to simply place your controls on a Tab Control (which you can paint transparent).
Then it's silly easy.
A simple solution is as attached.
/Y
Qestit Systems
Message 7 of 17
(3,947 Views)
           Thanq for your reply but i am using labview 2009. So, it couldnt open in my system , can you paste again the attachment in 2009 format.
                                Thanq so much.
Message 8 of 17
(3,913 Views)
one more thing how can i do with that textboxex like it can only take numbers not alphabets...any help..
Message 9 of 17
(3,910 Views)
Your indicators are not textboxes. They are numerics and cannot display alpha characters now.
Message 10 of 17
(3,876 Views)
