09-18-2013 06:07 AM
I have to send a signal to the MTS 407 Controller through a DAQ card..
Can i use function generator.vi to send signal to the controller..
can anyone help me on this..
09-18-2013 06:14 AM
Hi abhishek,
- the manual for that controller mentions some remote control via serial connection. You may use this to send values to the controller.
- When you want to simulate sensors, you can connect your DAQ card to the sensor input of the controller. (In that case you can use a function generator in LabVIEW.)
- The controller has a built-in function generator. You surely can control that one by serial connection as mentioned above.
You really should provide more / specific information on your actual problem to get better help!
09-18-2013 06:43 AM
Thanks a lot GredW.
to be more clear on this-----
i should send a signal(torque or Displacement) to the Actuator
Actuator is controlled by MTS 407 Controller..and i'm using a DAQ card(analog in/out)..
so what ever signal i'm sending to the controller should be continuous and
from the analog in,i get a corresponding response signal which i use for monitoring..
Can you help on the sgnal generation part of it.
09-18-2013 08:12 AM
You seem to be asking the same question over and over and over again. You were told to refer to the DAQmx examples that come with LabVIEW. If you truly followed that suggestion, you need to be specific about what example you are having trouble with. If you did not follow the suggestion, why haven't you tried one of them? You just can't keep saying 'need help' when you have been given help and you just start a new thread.
09-19-2013 01:48 AM
Sorry for it..
i found some examples in signal generation..right now i dont have hardware with me..so can i know that is there anyway to test that signal is generating to the DAQ..
